strange icon on screen | SatelliteGuys.US
rsdeepsea
Gulf Shores
when "info" is pressed, the regular status bar comes up, under that is the screen format (stretch), and under that is an icon that looks like the receiver with a green light on and a yellow warning triangle. Everything seems to work fine and I can't find any info on it. Any ideas?
Do you have a wireless connection to that receiver? If you do it's a warning that you broadband is not connected. Usually you can pull the connector out and reinstall it to fix the problem.
2 TVs, Same room, watch live or DVR synced?
ETA on OTA??
