Starchoice setup with acutrac 22 | SatelliteGuys.US
travelmickey
2
Hi I have a starchoice 75E dish with Quad out puts and A & B LNB's. B is 22khz and A is 0khz it says switchable. How do you hook up the Acutrac to get both LNB's. Manual that came only talked about Dish Sat setup are they the same? Thank you in advance Mickey
to get sat B which is 111.1 you need to turn on the 22k tone. If the meter has one (it should)
sat A is 107.3 and doesnt use a tone.
Easiest thing is to skew the LNB for both and then aim at 107.3
111.1 1will fall into place :)
Will this LNB work for Star Choice?
Why does Bell look much better than Dish HD?
