Starchoice Satellite dish | SatelliteGuys.US
1amp
I have a LM-2738-SC satellite dish that I would like to use with my RV as a mobile unit. The dish measures about 32" x 18" and is stamped with 60E. Is this dish suitable to use while camping.
It also has 4 terminials to connect the cables to.
Thanks in advance for your help.
If you have StarChoice yes it would work. Pretty small so as long as you're in a northern state (or in Canada) it should work fine. Farther south you get the worse it will be aiming the dish
Star choice is the only Canadian service for going south, even into Mexico.
We have been as far south as Morelia, Patzcuaro, Urapan, Zihuautanejo and back up north on the Ocean with great service.
You will need to get a new Dish and LNB to match.
The one you can get directly from Star Choice is
larger dish. Part Number 3041221; Mold number 75E.
The one you discribe is a 65E which is more difficult to aim and the 75E is much easier to set up and get a good signal strength.
Contact Star Choice and they will bill your account for about $ 50.00 and send directly to your address you state.
Good Camping.
leugy44
Star Choice & Bell Use the same Dish? or........
