StarChoice Quad LNB | SatelliteGuys.US
StarChoice Quad LNB
jenom
84
Somebody gave me an unwanted Starchoice dish,model 60E with a quad LNB.
The label on the LNB says:
Dual satellite quad output swithable Ku LNBF
Model name:LM-2738-SC
Left hand side: 0 khz Sat A
Right hand side: 22 Khz Sat B
Input Frequency: 11.7-12.2 Ghz
Output frequency: 950-1450 Mhz Non-Stacked
Linear Polarization
Vertical 10-15 V
Horizontal 16-20 V
Is it any useful with an FTA receiver ? (Captiveworks/Skyview)
Thanks !
yep. they work really good for all the legal FTA up there.
Dish is a little small but should get most of the stronger KU band signals up there.
I use the same Dish. It has 2 eyes so you can aim at 2 satellites. Mine is at Telstar 5 and AMC4. Get lots of channels, some I don't know what they say (foreign stuff) but there is some cool stuff there.
Thanks, it looks like it's maybe usefull, ----assuming that it still works !
I'm planning to try it out with 1 cable, look for strongest satellite (Galaxy, AMC ?)
Now I just need some help with the details:
1)It has 2x2 connection, on left 0 Khz SAT A, right 22 Khz SAT B, which one i use ?
2)Where do I set the LNB frequency on the receiver?
3)22 khz: ON OFF AUTO ?
Thanks!
All 4 ports will do both satellites. To see if it works, try Galaxy 3C at 95 degrees
11780 H 20760 is a very strong transponder (freq, pol, symbol rate)
Setup would be
LNB LO 10750
22k off (if using Sat A) 22k on for Sat B
120cm dish with C-Band performance - Now with HD!
No more dish aiming headache !
