StarChoice for French ONLY programming. | SatelliteGuys.US
DaveFormula
67
Québec & WNC
Hi,
I would like to get a StarChoice receiver mainly for French language programming.
I have both a DirecTV and Dish Network dish, so all that I need would be the SC receiver. What is recommended, as far as a SC receiver, and which dish (D* or E*) should I use?
Thanks. :hatsoff:
Dave.
you need a different dish & LNB. SC uses different setups than Dish/Direct
If all you want is French channels, you can get a single 30" dish and KU LNBF. The only thing not on the 2nd satellite (111.1) in the package is the 40 audio only channels. Those are on the main satellite (107.3)
Starchoice 75E antenna need help.
Bell ExpressVU Uplink Report - 8-4-2006
