Standard TV & HD receiver | SatelliteGuys.US
Rebollos
35
I ordered Directv using AAA and a HDTV from Amazon, but it looks like installation will be before the HDTV gets home, so can I use the Standard Tv with a HD receiver?
as long as your TV has inputs OTHER than RF, in other words, yellow, red & white RCA inputs you're OK. These are usually referred to as "line" inputs, or video inputs in your menu. If you have ONLY an RF input you're scrod. :cool:
AS HDinCincy said. Additionally make sure in the receiver setup that you tell it that you have a 4:3 tv. If you are using component or hdmi connection set the resolution to whatever your sd set can handle. If you are using composite or s-vid connections then it doesn't matter (always 480i).
Springfield/Holyoke, MA
Leasing Fee
