Standard Installation | SatelliteGuys.US
Here is what was on the back of my last service agreement:
Services: Site survey at the time of installation; assembly of dishes and mounts; grounding of system components to meet NEC standards; system peaking for optimum performance; installation of up to 20' RG-6 cable; routing of cable through one wall penetration; testing of equipment for proper operation; orientation to DISH Network programming and equipment.
Materials: up to 200' RG-6 cable; coaxial cable connectors; grounding equipment; weather sealant for connections and structure penetration; wall plate(s);; bushings and fittings as needed; mount hardware (standard eave, chimney, tripod, pole with up to 50' of trenching cable).
Non standard options: non standard options are in addition to the standard installation services as outlined above and are payable at the time of service
JD,
Basically, a standard installation is the mounting of the dish on an existing structure; house, chimney, deck, etc. Standard also include up to 100 ft of RG6 coax.
we charge extra for posts in concrete and cable over 100 ft.
fred
PVR 510 hard drive problem ?
Solar Outages for the Spring
