Standard def | SatelliteGuys.US
Standard def
I suspect it is somewhat less than 2000 hours avialable for "My Recordings".
At about 1250 recordings I was 99% full. Some of those were longer than 1 hour a few were half hour.
I believe some of the capacity is still reserved for rentals or on demand, which reduces the user controlled capacity.
Were they all SD recordings?
Also, you'll fit more SD on EA than on WA due to better MPEG4 compression.
They were mostly SD with a few HD.
Until I was able to use PTAT I recorded everything I could in SD to save space/increase capacity.
Now with less then 900 recordings I am over 90% full.
Still waiting for a fix for the transfer to EHD screen to see/select any orall the recordings on the internal disk for transfer to EHD.
Hopper upgrade
Freeing the PTAT tuner and keeping commercial hopping
