stacked LNB | SatelliteGuys.US
stacked LNB
jcrhomeent
2
OK is ther a way to switch a R22 to a stacked LNB, it already did teh damn software upgrade. When i go to the system diagnostics page it only brings up the phone. Any help would be appreciated
If you have a stacked signal, you can buy a DStacker that will split the one line into two. If you have a SWM line, you would just plug the line into the first tuner and keep the second one empty.
When do you pay "up front" fees?
STO now in HD
