spun aluminum dish | SatelliteGuys.US
spun aluminum dish
babcea
214
N.Florida
I have read this term alot but how do you identify one of these,I want to know so when I am dish hunting I will know what to look for,are they solid or the mesh type,I hear they are a good find,any info would be great:confused:
I don't want to steal Diamond Jim's thunder, but I found the pic of his spun aluminum dish
Damn that still is a sexy dish
that is a very nice dish,I have not seen one of those around,but if I do I will try to get it.the motor on that thing is huge,I would hate to have to replace one or those,I would have to take out a loan LoL.
how to tell
The dishes are made from a large disc of aluminum.
It's chucked up in what looks like a big lathe.
I think they're actually called spinning lathes, but ...
Behind the flat disc, is a male mold of the dish shape you want to achieve.
It could be made of wood.
Both pieces spin together.
The operator presses a long tool with a wheel on the end, against the middle of the disc to force it against the mold.
As they work the metal, they move from the center toward the outside edge, shaping the metal closer and closer to the curve of the plug.
The wheel on the end of the workman's tool spins to reduce friction and avoid damage to what will become the back side of the dish.
I've seen cooking pots made this way, but never a dish.
Will look for some links to dish fabricators, and post 'em if I can find some. edit: maybe these guys?
Basically, what the finished dish will look like has these attributes:
- aluminum
- one piece
- big - :rolleyes: - 'cause if it wasn't big, they'd just stamp 'em!
The solid Birdviews are spun, I believe.
They appear to have a support ring built onto the back side of the dish.
That is a separate piece, attached after spinning.
It's used for strength and mounting purposes.
c band reciever options
Big Dish Boneyard
