So it's been released on AT&T, T-Mobile, and now Sprint. Sure wish Verizon would release it already!!![]()
Thats what I'm thinking so far ... however, I have found that locally here, the 4G upgrade is finally getting somewhere...Not missing out on much though.
I have noticed one thing I do not like ...
On the LOCK screen, there now shows a Camera Icon, allowing me access to the camera from there, which means it's NOT really a Locked Screen anymore.
Wish I could find a way to remove it ...
I already have a Camera Icon on the screen inside the Lock screen that works fine.
If you have a passcode the camera option is no longer there.
So if I have a password to get into the camera the camera is not there ?
Well that defeats the purpose of those I have heard from as to why it's there then.
I have heard that they put it there for easy access, if I don't want it there I have to make a password for the phone, which I do not want to do, I have no need for one ...
This I find interesting ...
Camera is not on the lock screen if you have a passcode. Also it doesn't defeat the purpose as if you have a passcode nobody should be able to launch an app without the passcode.
We have a tower that is sending 4g now, not the one that makes it to my home, but it should be coming soon.
I went to south Texas for 10 days and was able to use 4G there ...
What I found was the battery life is much less than it was for the 3G service ...
Is this what others are finding as well ?
That also may depend on the speed of your LTE network. It varies around here from tower to tower but on the weaker ones I do see a little more battery consumption. Have you tested your speeds yet on LTE?
Limited time offer
