Sports Mix HD added 205/600 | SatelliteGuys.US
jamieh1
528
188
Greenville Washington New Bern, NC
Sports Mix HD has been added on ch 205 and 600.
The SD version will be dropped soon
(from directv.com)
SPORTS MIX Transition from SD to HD
The Sports Mix Channel is being enhanced and will no longer be available in standard definition. From now on Sports Mix will be delivered in crystal clear, high definition to meet the needs of our sports fans who want to see their sports coverage in the very best format possible. You can still find the full-time standard definition sports channels that were showcased in Sports Mix in their current channel positions. We made the decision to repurpose the satellite capacity (previously used to for the existing standard definition Sports Mix) to deliver a higher quality viewing experience by delivering the Sports Mix in high definition from now on.
Except that it's useless if you can't move the selection around ...
Looking at it at the moment, basketball is on the channel top left, I try to move to the left and it loads my Apps, to the bottom it wants to start double play, pressing select does NOTHING.
Jimbo.
Wait a few seconds. The blue square should show and then you can move it from box to box.
Good find!
Mine moves fine from square to square.
Like it now in HD..
Almoat Never did tune in in SD
So by the looks its not a 24/7 channel as French open is on.. yuck!!
Yes, I typed the wrong direction, Apps are to the right.
I literally meant when I push the right button, the audio moves to the right but the apps also appear. Today, the client was working properly but the Genie itself is not.
One of the worlds best weather predictor: the satellite dish...
Thinking about leaving dish for directv a few newbe questions.
