Splitter | SatelliteGuys.US
Splitter
RCDAVIDSON
4
I ran 4 lines, one to each receiver, when I first had my dish installed. Last night I got my 622 and will be disconnecting the 811 and 510. Should I use the splitter
that came with the 622 and only use one line,or is there an advantage to use both lines and feed them two both inputs ?
If you have DishPro Plus with a DP44 switch, use the splitter. If you only have DishPro and a DP34, then you need to hook both lines to the 622. The only advantage is if you DishPro Plus, you can add another receiver (even dual tuner) without buying another switch.
UHF Remote for TV 1?
