Splitter Question | SatelliteGuys.US
Splitter Question
charlesrshell
SatelliteGuys Crazy
11,251
5,982
O'Fallon, IL
Can satellite 5-3GHz splitters be used in place of the 5-1GHz splitters? During my research I have read both yes and no. Will it work OK but it is best to use the 5-1 GHZ when appropriate, etc? Thanks for all that respond.
Sorry but I don't understand your questions. What are you trying to do? If you are trying to split a DISH Network signal you can't except in very limited applications. You use Multiswitches for increasing the number of receivers off a single DISH.:)
Where to Compare HD Packages?
Does the 6000 pick up OTA HD?
