Splitter question | SatelliteGuys.US
Splitter question
Zaxcom
114
Charlotte, NC
When the tech put my system in he only used one client tap on the dual node, and put a three way splitter on for my 3 Joeys. Would it make more sense to use a 2 way splitter and put the 3rd Joey on the other client tap on the Node? Do MoCA splitters have signal loss like regular cable TV splitters?
Do I need to buy a specific kind of splitter if I want to change this?
Thanks.
The install is correct per the wiring diagrams. I wouldn't mess with it unless you have problem or there's clear info that this setup is not recommended by Dish anymore.
Thanks.
There is an old saying that applies here.....
If it ain't broke, don't fix it.
If you are not having any problems, i'd leave it alone.
Anyone having an issue with broadband failing on Joey?
I think the spark is back in R relationship
