"Splitter" help.... | SatelliteGuys.US
"Splitter" help....
smokey982
2,050
161
Cleveland, TN (Chattanooga Market)
I'm trying to find the name for a "splitter" that was used on my last install by a Dish installer. I have a single RG6 cable coming into my 622 and that's where the "splitter" was installed, to split into my 2 tuners. Does anyone know the proper term for this device and where's the cheapest place to buy one?
All I want to know is, is it the pro model?
msmith,
The only way to be able to serve more than one Satellite tuner from a Single Satellite Coax feed is to use Dish Pro PLUS hardware. Hence, there is only One Separator, and it is, and I know this might sound familiar, is a Dish Pro Plus Separator.
John
You said Dish Pro PLUS Hardware. Any particular kind of hardware, or will any work?
Ok, sorry. Couldnt help it:p
It needs to have a Dish Pro Plus LNB or a Dish Pro Plus switch on your dish in order to work. Otherwise to seperate lines in are required.
Signal issue any help is appreciated
What LNBs do I need?
