Splitter configuration | SatelliteGuys.US
JerseyMatt
1,193
2
Midwest
Not exactly Directv specific, but just wondering if anyone makes a splitter with the input and outputs all on the same end. Basically I need to put a couple splitters into standard 4x4" junction boxes (one per), to avoid homerunning. The boxes are connected via 1/2" conduit which is set into concrete. The conduit is already a very tight fit with one RG6/QS coax and four Cat5 cables, so it must be split along the run (this is for FM in my basement). I already tried it with a standard 2 way, and it fits, but only one way (diagonally across the box) and it kinks the cable at the input and output fittings. If all three connections were on the same side it would be a perfect fit..
Anyone ever seen one like this?
Are these just regular splitters that you are needing for cable/vhf/uhf tv? Or are you needing to split a signal coming in from the DirecTV dish? If it is just regular uhf/vhf try looking and seeing what Channel Master, Leviton, and Winegard make.
Add receiver, H25 to HR24, fees, contract
Directv in Alaska
