Spellcheck | SatelliteGuys.US
Spellcheck
Not open for further replies.
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,731
29,519
Newington, CT
I am currently installing a new Spell Check system, this new spell check system is supposed to work NICELY with the site including the WYGIWYG editor.
While I am working on it the current Spell check may be unavailable.
Thanks for your understand and support of SatelliteGuys! :D
Well the new spell checker does not work, as I found out after getting it all installed, it seems as though our server has Aspell installed instead of Pspell. So I will need our server weenie LER install Pspell. :D
Once it works I think you guys will like it. :)
Sorry for the delay.
Spell check is something I need badly. Thanks Scott for the quick reply about the promos. Wish the 522 would be part of that or the 721. oh well
We have spell check now, just the one we have now does not work with the WYSIWYG Editor.
The new spell check also allows you to add words to the dictionary that come up as being misspelled but are spelled correctly.
We will get it working. :D
To administrators--control panel help
Please Remove Scrolling in Post/Threads
