Special antenna for OTA HD?? | SatelliteGuys.US
smokey982
2,050
161
Cleveland, TN (Chattanooga Market)
I have an uncle that just purchased his first HD LCD and has been trying to pick up his locals OTA. He has a very old antenna that he has used for the last 15 years to pick up OTA analog channels and it works fine for analog. Clear picture, no ghosting .
But when he tries that same antenna on his new TV with built in HD tuner, it will not bring in any digital channels. The TV says "the signal is too weak". Antennaweb shows he is only 20 miles from the local towers.
My question is does he need a "newer" or "HD" antenna to bring in the digital channels?
seems like it should work. Many HD channels are on UHF, make sure his antenna picks up UHF. See if the TV has more than one antenna input. My Sony lcd has two antenna inputs one for cable one for OTA. Make sure you are scanning the correct input. Does the new tv pick up the analog stations ok? at 20 miles HD should come in fine. check out this site www.antennaweb.org When I put in your zip it shows only 2 digital stations NBC DT on channel 13 and WB on channel 42
Chattanooga 86
WELF IND 23.n 16
WRCB-TV NBC 3.n 13
WDEF-TV CBS 12.n 47
WDSI-TV FOX 61.n 40
WTVC ABC 9.n 35
WFLI-TV WB 53.n 42
WTCI PBS 45.n 29
However these are other DT stations in Chatt. don't know why they dont show up in antenna.org.
I also use one of those old antenna's and it works fine, the problem is if u are not right on the target it will not pick up an HD feed. Analog is fine if u are close but not HD keep pointing in the direction of the towers and you shoud get it with some tweeking.
The big thing to remember is that even though it is now broadcast digitally, HDTV signals are still broadcast on good ol' UHF and VHF. So, any antenna capable of dialing in those in the past will work just fine for HD/digital broadcasts. I'm in agreement with Marty43 on this one, make sure the antenna is cabled up to the right co-ax input and that your uncle has a solid connection between the antenna cable and his TV. Antennaweb.org is also a good point of reference.
Though every situation can be different, in my experience analog has been more dificult to pull in than digital, especially channels 2 through 6. The fact that your uncle has good reception on stations like that suggests to me that he may have used the wrong input for the antenna on his TV.
Just checked your local stations -- I assume he's also in the Cleveland TN area -- and the old analog stations are primarily UHF, so that's good. I was expecting that they were all VHF and he had a VHF-only antenna but now needs UHF.
What kind of cabling is run from the antenna to the receiver ?? It should be RG6, not the old twinlead.
All of the main Chattanooga stations are grouped fairly close together, between 271' and 284'. That's completely doable with most antennas. I'm using zip code 37311, by the way.
" What kind of cabling is run from the antenna to the receiver ??"
Should splitters and other connectors between the antenna and the HD tuner be checked for digital compatibility too?
Years ago (before I had dish), i had to switch out my splitters when I went from analog to digital cable. I'm assuming the same would apply to OTA??
Some people that can pick up their UHF analog stations fine have problems picking up their digital UHF stations because some of stations are not broadcasting at full power yet (or have much lower power or different antenna locations) on their new digital stations. Checking http://www.antennaweb.org may help.
It turns out he was using the wrong antenna input on his TV. But he was also using the old twinlead wire. We were still able to pick up 2 channels with his old setup. He's going this week to purchase some RG-6. Thanks for the help.
There are only 2 stations broadcasting digital in the Cleveland, TN area
* blue - vhf WRCB-DT 3.1 NBC CHATTANOOGA TN 275° 24.0 13
* blue - uhf WFLI-DT 53.1 WB CLEVELAND TN 284° 22.3 42
Have him get a new adapter --the piece that adapts from the antenna to the RG6, if he is using twin lead he probably does not have one.
Actually, Antennaweb is incorrect. I can receive all of the local networks digital feeds from my location. I'm not sure why it only shows those two.
How Do You Get New Software Updates?
HD Aspect Ratio
