Sparkies | SatelliteGuys.US
Sparkies
chefwan
752
South Carolina
what cause sparkies in some channels ill adjust the polarity and still you can see the alittle and i've changed LNB's it fixed it less sparkies but its a few here and there why is that?
A dieing LNB will have many, a quality lnb should not have much, reflector size and alignment also have to do with it with a lower quality lnb you will have a lot of drift so you should be able to adjust the lnb off set should be in the menu somewhere, you can try bumping and fine tuning chances are on some feeds you will always see some white or black sparkles if there is to much chances are you are off a bit on alignment or the lnb is not that great.
FD ratio is also very important, and make sure the feed is aiming to the centre of the reflector, if the feed has a adjustable ring with one key screw to hold it keep an eye on it when you tighten it, you can tighten the ring on slightly crooked loosen and hold it good and get it straight.
How to tell if HDD-200 has GUI
FTA coolsat 5000 receiver
