Sound Synch on HBO | SatelliteGuys.US
Sound Synch on HBO
rlstjohn
22
Millersville, Maryland
Is anyone else getting sound synch problems on the HD HBO channel? This has been going on for a while now (well over a week) and reboots don't seem to fix it? Ideas?
rlstjohn said:
I have the H10-250
Do those have an on-screen listed software/firmware version number? If so, post it, and the others can see if maybe that is some issue; I do not use that make & model. But just checked again and still no audio sync issues here. Maybe MJones can help out with that software version comparison. Good luck.
I noticed a sync problem on HBO today as well. However, my Yamaha receiver that I use for my downstairs home theater has an audio delay feature. The audio can be delayed up to 160 milliseconds. This cured the problem for me on HBO. However, when I turned to another channel I had to lessen the delay.
When I got my Sony KDS-R60XBR1 I started getting delays on all channels because with the video processing it does it makes the audio sent directly to the home theater from the D* receiver get out of sync with the video.
Look At This
Access Card
