Sound on HD Channels | SatelliteGuys.US
danel-ksc
14
central florida
The audio on HD channels is significantly lower than the same SD channels. Flipped receivers around TVs and it is the same for all HD receivers and TVs. Clarity is fine, just have to turn up the volume on HD vs SD.
Is this normal or is my audio reception on HD off for some reason?
My new-ish HR22-100
Ok !! How many of you switched
