Sound on hd channels | SatelliteGuys.US
BruceE
80
I have a problem with the audio on my HiDef channels. Anyone else have this problem or have any idea what my problem is.
Thanks,
BruceE
The problem is having "DISH" the sound drops out almost everyday...the worst time is during prime time shows. It doesn't do any good to complain to "Dish,they never seem to have heard of this problem before.
Audio on HiDef channels
The audio on my hd channels are fuzzy. The audio on the sd channels are fine.
Thanks,
BruceE
It is crucial in these threads that you mention which channel is causing the problem.
( papayazz - if you are referring to a problem that only happens on ABC & FOX, then it is a known problem. )
Audio on hidef channels
All of my hidef channels have a fuzzy audio sound. I can't even watch them the sound is so bad. It's just not one channel but all of the hidef channels.
Thanks,
BruceE
Are you using your TV speakers, or a surround-sound receiver, or what?
OK This is odd......
Losing signal-110/119/129
