Sound Dropouts On Channel 191 | SatelliteGuys.US
Jeff003
245
Has anyone noticed any sound dropouts on channel 191 tech tv.They are occuring on both of my 301 recievers.Sometimes they are about a second but than they can last from 3-5 seconds the next time.They are occuring quite frequently like every couple of seconds to a minute.The picture is good I'm just getting audio dropouts.I don't know if it is my dish causing the problem or it is with tech tv or maybe the satellite up in space.Any info would be appreciated. :(
Remember, tech TV turned into G4 today, or whatever they are calling the merge, so that could affect it.
If this is the only channel your having problems with, I'd say it's the channel and probably doesn't have anything to do with your system.
Hello all I'm no longer having this problem.It must have been the tech tv merger with g4.Thanks for the suggestions anyway.
Dish VOD question
The manual housecleaning myth
