Sony KP48S65 RPTV 50" green screen with lighter green diagonal lines. | SatelliteGuys.US
Rathergood
2
Birmingham, AL
Hi, I have a friend who mother owns the above TV. He states then when the TV is turned on it displays a full green screen with lighter green diagonal lines. The sound still works but the screen is green. Could you guys tell me what the problem could be and how much it would cost?
Thanks!
Rathergood
I have hesitated reply for someone to give you a direct answer. I am by no means an expert on tv repair, but I had a close friend who worked with me fixing tvs. If my memory is correct the issue you describe is caused by the green picture tube shorting out. It draws more juce and creates the green screen by causing too little voltage for the two good tubes. Wether or not just changing the one tube will fix your set, I do not know. If you take it to a tv shop for repair it will sure be $250-$400. Most repair shops will give you an estimate for $50 or so. But if you do not want to put much money in it. The money paid for an estimate could be part of payment for a new set.
HD-DVD Player - Upconverting
Hitachi vs69 opinions
