sonicview 8000 question | SatelliteGuys.US
tobor26
23
Ottawa Ontario Canada
Hi everyone .I run a sonicview 8000hd. I have it hooked up to an invacom lnb and hh90 motor.I have about 25 sattelites scanned in.My question is when I try to listen to the audio stations on G25, the audio cuts in and out.I've had this receiver for about 1 month,so it is new to me.The signal on G25 is about 45% on the radio side.So should it be higher to get better reception? or are my settings not right? What should my setting be for G25. I've had fta for about 2.5 years now using other receivers and had good recepton from G25 before. Thanks in advance .
Why not compare the Q level of the G25 radio channels with another radio channel that you receive well. It's very possible that the problem is with the source of the signal, but finding what good levels are for your receiver should be a good small project.
offset scaler ring
Bob jones university dish
