sonicview 360 hd | SatelliteGuys.US
sonicview 360 hd
dennis12
151
On another board they are saying this receiver will do both blind scan and dvb-s2. Can anyone verify this. Dennis
Seems odd they would name it 360 HD and it not be HD capable, maybe its referring to hd as hard drive as in pvr. I've read elsewhere dealers have been told its hd and will do dvb-s2 and blind scan. I think they are all waiting for the box and then will report what it will do. So much hype, so much waiting.:(
There are 2 models....the 360 and the 360 HD
one has HD but the other does not...and as brent noted, it could be vapourware
Saw this on a site that is taking pre-orders "SonicView 360 Dual Tuner HD PVR", I'd say its a High def unit....will just have to wait until someone gets one and reports on it.
Sonicview 360 Elite is the name.
Features
* Fully MPEG-2 & DVB-S Supported
* 2 Tuners and Blind Scan Supported
* 3 USB 2.0 Ports for External HDD and USB Memory Stick
* S/PDIF for Digital Audio / Dolby AC-3 Bitstream Output
* RCA and Components Outputs : Y, Pb, Pr
* S-Video Output
* USALS Supported
* 16 Bit (65,536) Colors & User Friendly GUI for Easy Control
* Fast Booting and Scan Speed
* Signal & Multi-Satellite Auto Scan
* Manual Scan Supported
* High Speed Channel Changing Time: Less than 1 Second
* 6,000 Channel Memory Capacity for TV and Radio Programs
* 8 Programmable Favorite Channel List Groups
* Channel Sorting by FTA, CAS, Satellite, Alphabetical and Network
* Picture in Graphic Available
* Zoom In / Out function for TV
* Various Aspect Ratio with 4:3, Letter Box, Full Screen & 16:9
* Background Graphic Display for Radio Program Channels
* Parental Lock Function Using Master PIN Code
* 20 Step Volume Control
* Useful Remote Key Functions for Channel Find, Edit and Signal Strength Display
* Dual Record & Playback Simultaneously Using External HDD
* Dual Recording and Time Shifting Simultaneously Using External HDD
* Time Shifting Supported Using External HDD
* Powerful Trick Mode Supported Using External HDD
* Live Picture in Picture (PIP) Supported
* Music and Photo File Supported
* 2 Year Manufacturer's Warranty
Not HD unit only dual tuner pvr
hehe, what confusion, the Elite, and Premier have been around for a while, go to Soniicviews website, they have both been available for a while. What the op was asking about in his subject line is the Sonicview 360 HD. As I said in my post above pre-orders are being taken now, it is indeed an hd unit.
Dennis12, I believe Rick is supposed to have his shortly so maybe we will have some news.
The Sonicview 360 has 3 verisions
360 Elite- dual tuner for recording (standard def). This unit was released about 2 weeks ago.
360 Premier- single tuner for recording (standard def). This unit was just released this weekend.
360 HD- dual tuner for recording, and will be released in about 3 weeks.
I will post if I hear anything more news on the release for the 360HD.
Cheers
Yes. I talked to Rick on the other board. He said its suppose to support dvb-s2. But he wont know for sure until he get one to work on. Which is suppose to be sometime soon. Dennis
Thanks Dennis12, I don't know why I get so excited about these new receivers, in the end there always seems to be something that they are missing that I want....you would think I would learn:D Anyway, heres hoping for dvb-s2:up
SV8000 / 16 LNB setup needed
LNBF with Dielectric.
