Some questions | SatelliteGuys.US
Some questions
maznblu
3
Michigan
We're moving in a month to a house with no access to cable and are trying to choose between Direct TV and DISH. I've got some questions I thought might get quickly answered here.
1. We'll want to hook up 5 TV's at the house (preferably all HD). Will the Hopper system on DISH TV support that?
2. The house is wired into 5 rooms for TV now, but 2 are not the rooms where we want it. Will DISH wire to the rooms we want as part of an install or would I have to have someone else do it? Is that just a single coaxial cable to each room?
Anything else I need to consider?
Yes. As part of your install dish will run the lines to where your tv's are going. Try and keep the cable runs reasonable as "we" are not magicians. The H/J system will allow HD to all viewing locations. For 5 tv's you would get a 2H/3J set up. Although not an officially supported method, Joey's can be run without coax, although depending on your installer they may or may not be willing to do this for you.
What part of the state are you in?
Go Blue!
Locals removed from EA, anybody else?
Random Channel Change
