software updates | SatelliteGuys.US
software updates
gmcgown
65
Fort Worth
I noticed somewhere that both the HD and SD sets used with the 622 must be off to receive softwear updates during the night. My wife watches SD late and never seems to get the the STB turned off when she turns off the TV. Have I missed any important stuff over the last thirty days?
The TV sets don't have to be off, but the 622 itself does need to be off. What setting do you have for the inactivity timer? I believe the default is 3 hours, then it shuts itself off.
The default for upgrades is 3am. You can change it to any time you want. If you want to be certain (at any time) that you have the most current software, change the upgrade time to several minutes ahead of the present time and turn off your 622. This way you actually observe the download process (exciting stuff indeed). Just don't forget to reset to the default when you are done.
Jim5506 said:
What has our education system come to. I see more phonetic and erroneous spelling now days.
Your first sentence lacks proper punctuation. I think nowadays was the intended word in your second sentence. Aside from that, I completely agree with you. ;)
If you are ever up watching when the 622 is set to update it will give you a warning that it is about to reboot. If you don't tell it to stop it, it will do so and the daily update will occur. (not hard for me to see since I have the one in my bedroom set to update at 7am) So unlike some of the machines it does not have to be off.
OH NO... it must be catching!!!
jlm -- IRT "What is a 622?"
The ViP 622 is a fairly new model, DishPro Plus dual tuner High Definition satellite receiver, that also has a (digital) OTA tuner and a DVR (digital video recorder), for use with Dish Network DBS service.
It has a lot of nice features.
Dishnetwork or Echostar makes them and they are the latest satellite hd dvr with mpeg 4 /mpeg 2 capabilities. For sale at $499.99 and for lease from Dish for $199.99. I have two of them and I love them. THey do both sd in 480i or hd simultaneously- hd in either 480p/720p/1080i.
vip 622 dvd-r
Help and Advice needed please...
