Software updates | SatelliteGuys.US
Software updates
Can someone send me a list of software versions for vip receivers?
ReceiverCurrent Version(s)Release DatePrevious Version(s)Release Date
922S1.32Dec 2018S1.31Jun 2017
722KL9.28Feb 2022L9.25Aug 2020
L9.27Dec 2021
722L9.17Feb 2022L9.14Jun 2019
L9.15Aug 2020
622L9.31Aug 2020L9.30Jun 2019
612L8.97Aug 2020L8.96Jun 2019
222KL8.84Feb 2022L8.82Jun 2019
L8.83Oct 2019
222L7.64Jan 2022L7.63Jun 2017
211KL8.67Feb 2022L8.64Jun 2019
L8.66Dec 2021
211ZL9.01Aug 2019L9.00May 2019
211L5.77Dec 2021L5.76Jun 2019
L5.75May 2019
411L5.76Jun 2019L5.75May 2019
L9.27Dec 2021
L9.15Aug 2020
L8.83Oct 2019
L8.66Dec 2021
L5.75May 2019
Sure has been a long time those receivers got a software update lol. Are these receivers going to get anymore software updates?
Can a customer have one VIP211 and one Wally on Hopper account for tailgating/camp purposes?
I don't think VIP receivers are compatible with Hybrid LNBs lol, however, someone said they will work with Hybrid systems lol.
Reactions: charlesrshell
You can make VIP receivers (at least one) work Hybrid LNBs with a DPH42 switch in between.
I think you have to have DPP LNBs with DPH42 to work with VIP receivers. Are DPH LNBs compatible with DPH42 switch?
Good catch, you having been reading my other posts.
You are correct that my current configuration is a DPP LBA to a DPH42 switch to a VIP receiver (via the same port as the power inserter). This is (albeit unusual) a Dish sanctioned configuration.
However, I have been told that using a DPH LBA to the first two ports of the DPH42 switch, with the same backend configuration, should work just fine; albeit not a Dish sanctioned set up, so YMMV..
I'm going to find out soon. My current DPP LBA is getting flaky (15+ years old) and I'm going to try replacing it with a DPH LBA (a three horn one with the 129 horn just ignored).
If I guess wrong and it doesn't work, I'm only the price of a DPH LNB. I would then have to get an old DPP LBA; if I could find one. I promised to post back my results when I do this.
You definitely don't have worry about finding 129 anymore because 129 is no longer in business lol. There are probably some installers are putting stress on themselves trying to find 129 lol.
I seriously doubt any installer, at least professional installers, are looking for 129 any more.
Recorded Shows skipping to the end
NBC and ABC OTA channels are gone
