H havenx SatelliteGuys Pro Original poster Sep 1, 2005 211 0 Oct 18, 2005 #1 I did a smart search and I only got like 4 channels. My sig and quality are running in the high low 90s.
H havenx SatelliteGuys Pro Original poster Sep 1, 2005 211 0 Oct 18, 2005 #2 oh yea, pansat 2700a invacom quad lnb with LP hooked up only.
J jh98 SatelliteGuys Guru Dec 30, 2004 138 0 Oct 18, 2005 #3 You should have gotten a lot more than that. Most of the channels on G10R are vertical polarization. Maybe you scanned horizontal only?
H havenx SatelliteGuys Pro Original poster Sep 1, 2005 211 0 Oct 18, 2005 #4 jh98 said: You should have gotten a lot more than that. Most of the channels on G10R are vertical polarization. Maybe you scanned horizontal only? Click to expand... I have H and V, now here is another funny thing. I am pretty sure I am pointed at G10R but I am getting AMC2 G5 AMC1 sat 81 and sat 82 as well. When I do the smart scan on each one I only get two FTA channels. PAC1 and test.
H havenx SatelliteGuys Pro Original poster Sep 1, 2005 211 0 Oct 18, 2005 #5 also on tp 2 thorough 10 on g10r I have no sig, but the rest of the tps are fine. EDIT: its like that on all of the birds
N neil_kc1 SatelliteGuys Pro Oct 14, 2004 402 21 KANSAS CITY AREA Oct 19, 2005 #6 Sounds like you missed g-10 and are focused on galaxy 13-horizones1 at 127 W the 2 channels you can see are located on that sat and not g-10. bump you dish back to 123.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,439 15,073 Mankato, MN Oct 19, 2005 #7 you're at 127...need to move it east a little bit for 123
H havenx SatelliteGuys Pro Original poster Sep 1, 2005 211 0 Oct 19, 2005 #9 would moving the dish about an inch to the eat be pretty close?
PSB On vacation Nov 5, 2003 3 5 Oct 19, 2005 #10 Use your signal quality meter, enter a LIVE channel from G10R then move the dish until you see signal quality.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,439 15,073 Mankato, MN Oct 20, 2005 #11 to move 4 degrees (from 127 to 123) is about 3/16" on the mast but as Pete mentioned..enter a frequency and watch for qualitry
