Small Technical Question | SatelliteGuys.US
jdmacor
701
Houston, TX
One feature on my old Comcast DVR was that I could be in the middle of watching a show or movie or something, push the record button, and the DVR would start the recording using the already buffered content and then start adding on to the recording. Dish's receiver just starts recording from the point where I hit the button. Is there anyway to duplicate the Comcast feature?
Yes, 1 hour ... but that is assuming the receiver has been sitting on the desired channel. If you were on channel X and then switched to channel y that was already 30 minutes into its program and you wanted to get the first 30 minutes ... no go.
Need Help with 622 Ethernet Connection
Can I create 2 partitions for ExHD to use with PC & DVR?
