Slingbox question | SatelliteGuys.US
Slingbox question
Chris36
448
4
Rhode Island
Can you used a Apple TV with AirPlay from your iPhone to used the Slingbox App or it won't work through the Apple TV??
Thanks,
Chris
Oh okay. I read a while ago that Boxee TV had the SlingPlayer App I don't know if I should buy that or not.
Guess I won't be getting one then. Glad this came up as I was thinking of doing the same thing with ipad and an apple tv.
It works on the iPad using the iPad mirroring function The mirroring function is only available on the iPad not the iPhone or iPod
Cool Thanks!
Not a big iPad user, so I'm not familiar with it as much as my android. Right now I use my Thrive and a 25ft hdmi cable when I travel for extended trips.
Denon Video Mode Issue
Home Theater Geeks 150: Improving Audio One Speaker at a Time
