D doltonjn Active SatelliteGuys Member Original poster Aug 22, 2006 16 1 Claremore, OK Mar 16, 2012 #1 Will a Slingbox Pro HD work with a Hopper?
isaacmorseMI SatelliteGuys Pro May 5, 2009 4,734 1 Southwest Michigan Mar 16, 2012 #2 Yep. Sent from my iPad 2 using Forum Runner
D doltonjn Active SatelliteGuys Member Original poster Aug 22, 2006 16 1 Claremore, OK Mar 16, 2012 #3 I am concerened about the bluetooth remote of the hopper.
N n0qcu Supporting Founder Supporting Founder Sep 7, 2003 5,159 2,012 Earth Mar 16, 2012 #4 the remote is NOT bluetooth. the Hoppers and Joeys can be controlled by IR which is what the slingbox uses
WheelieMan711 SatelliteGuys Family Feb 22, 2012 53 0 Colorado Springs, Colorado, United States Mar 16, 2012 #5 You'll just need to enable IR in the settings of what you connect the slingbox to (hopper/joey).
