Slingbox control of 622/722? | SatelliteGuys.US
noremac
251
Wash, DC
Has anyone been able to successfully control a 622 (or 722) via Slingbox - using an IR remote channel other than #1?
The only Slingbox profile I found is only capable of using IR remote channel 1, and I really need to change the default channel on my 622 to something else (i.e. 2, 3, 4, ...) in order to use a DTVPal in the same room (the DTVPal can only use channel 1).
Can you guys tell me exactly what device designation you have selected within the Sling menu?
My choices are, among others:
VIP 622 (this one defaults to IR channel 1)
DISH (remote address 2)
DISH (remote address 3)
DISH (remote address 4)
DishPro (code 1)
DishPro (code 3)
DishPro (code 4)
VIP 722
other
DishPro (code 1)
DishPro (code 3)
DishPro (code 4)
VIP 722
other
I used "DISH (remote address 3)" to control my 522 and it works great...
Search Menu Problem 622/722
ABC HD SOUND DISTORED
