Sling Guide Beta | SatelliteGuys.US
Sling Guide Beta
M Sparks
1,946
I got an invitation to join the Sling Guide beta, but whenever I try to sign up, it says my 622 is not online. All the diagnostics are fine, and it says it's connected. Triple checked the receiver ID, reset the connection a few times...no luck.
Has anyone else managed to get past step one? I'm wondering if it doesn't like Homeplug connections.
Yes, I got through, but I'm using a gaming adapter, not Homeplug.
I've got a 100' ethernet cable that I use for monitor transmission on field shoots. I'll roll it through the house and try hooking it up directly. Maybe I'll even just hook it right up to the modem until I get it set up.
EA Install
Surround sound on 2nd dish connection
