slimline/ hr22 upgrade help | SatelliteGuys.US
vzdude
2
I just bought a hr22 and a slimline dish and need help with configuration. I also am trying to hook up my dvr r10 to the same new slimline dish. My Q is this, will both of these receivers work together? What setting do I use for the hr22 in the dish type (dish has 3 visible lnb's, but has 4 cables)
anything will help at this point
Rick
Well a HR22 obtained from D* would have probably included the Slimline dish and installation. It dosen't sound like you really have any idea what you are doing so simplest solution is 1-800-531-5000 and see what they will charge to get it done right.
? about HR22 receiver
12 year Dish Network customer seeking change
