Slimline Help in Oregon | SatelliteGuys.US
skypros
2
I have not put many of these in (like 4 total)
I moved from California to Oregon
I had the slimline working fine in CA..... But now when I try and hook it up I do not get satellite 103 (s or c) my 99 s has great signal strength.
I have moved the dish to 3 different locations and all the same result no 103 but I get all others good.
I assume the 99 s satellite is a spot beam for the locals.
One other thing.... I do not know if this matters or not..... but my account is set up in CA (los angeles) and am getting abc, nbc, cbs & fox from LA in standard deff.... and our Oregon locals are not in HD yet.
I wonder if the LNB is bad.... But I find that hard to believe?
You will not be able to receive LA HD LIL in Oregon because they are on a spotbeam.
There is no indication that there is anything is wrong with your equipment.
No Signal Strength On Odd Transponders for Sat A(101)
Time to Replace HD-DVR
