But you DO understand that if the slimline was originally installed with ONLY a 3LNB, it was actually NEVER dialed in on 110/119 to begin with. When you install a 5LNB, there is an extra step you are supposed to go through on the dish in fine tuning the tilt & checking the signal on a 119 x-ponder. Obviously an installer can't do this if they are installing a 3LNB - which is why I gave the answer to the OP that I did.![]()
And it's NOT that "dialing in" 110/119 is difficult, it's that it's a little more difficult to dial them in & NOT screw up the signal on the Ka birds. (THAT'S why the techs like the 3LNB slimlines better than the 5's)
But if the OP finds the 119 signals "below par" after changing the LNB, it CAN be touched up - but you still have to know what you're doing as I just said.
You have done these before, right...
I'm just guessing that since 110 and 119 have a much larger "fudge factor" in aiming that putting the sl5 on where an sl3 was properly aimed will require no further adjusting.
Yes you need to tweek going from SL5 -3.
But very Minor!
I just did mine 1 week ago.
Signal seems better with the 3 LNB, my Guess is because your not stetching out to get the 110 and 119 thats a pain if there are any trees around.
Which is why I'm guessing you've actually never have even done one - I got it!![]()
AbsolutelyUh OK, but did you ever try to peak it BEFORE you changed to the 3? If not, then how do you know your dish was always peaked correctly on the 5LNB? Just because you needed to do it on yours, is NOT the correct conclusion that you always have to repeak, but whatever...![]()
I don't care how it was designed, to take something thats Big infront of a reflector, and replace it with something half the size, and weight your bound to need a small ajustment.Uh OK, but did you ever try to peak it BEFORE you changed to the 3? If not, then how do you know your dish was always peaked correctly on the 5LNB? Just because you needed to do it on yours, is NOT the correct conclusion that you always have to repeak, but whatever...![]()
If the dish is peaked correctly, you should NOT be having to repeak going from a 5 to a 3 - & if you DO have reception issues on 119, then obviously that's going to affect how you peak. Whether you are using a 3 or 5 LNB, the slimline dish was designed with it's main focal point on 101, since the Ka birds are on both sides of 101; it should ALWAYS be peaked for the maximum signal on those 3 birds, & as best as can be on 119 w/out reducing the signal on the Ka/101 birds, since the Ka signals are MORE touchy than the 119 signals.
Com'on, if you don't want to bother repeaking after you add or change something on your dish , well thats on you.
So if you ajust your dish with a Cinderblock on the LNB arm, and then replace the cinderblock with a Brick, your going to tell me the dish won't move slightly up?No, it's on you, because I simply do it right the first time & don't need to, since I understand how the dish is designed - guess we'll have to agree to disagree on this one...
Hey guys, Don't tweek it!SL3 = 2.39lb
SL5 = 2.96lb
Thats less than an 9oz difference. Not going to affect that dish much if any. It's not like the SL5 is that much heavier.
SL3 = 2.39lb
SL5 = 2.96lb
Limited time offer
