sl3 alignment | SatelliteGuys.US
sl3 alignment
wascallyrabbit
NOVA
having done some searching and watching various how align videos how do i align a sl3 slimline dish if nothing is on the 119. does the sl3 slimline even see the 119? so how do you dither to ensure that you get the hd on 99 and 103? the asl-1 outputs are for 101 and 119 is this still used when setting up the sl3 slimline?
The SL3 does not look at the 119. Only uses the 99,101, & 103.
Basically you just point it at the 101. If you have a level mast it's just a matter of fine tuning the elevation and dither to get the best signal on 101. 99 and 103 should be there if the rest is right.
What is Direct TV HD extra pack??
Will MRV Echo Programming?
