Skybox S9 FW Fixes Openbox S9 22Khz Problem | SatelliteGuys.US
  • Thread starter Thread starter yankee495
  • Start date Start date
  • Replies Replies 0
  • Views Views 2K
yankee495
336
62
Southwest Missouri
Jim S. Wrote:
"The Skybox S9 file posted on wydvb.com works fine on an Openbox S9. The switching problems have been fixed, as far as anyone has reported so far. (I know the 22k problem is fixed.)
I'm still using the pre-green-fix firmware though because the blind scan is too slow on certain satellites on the new versions, and I don't use the standard-definition output anyway."
I must say Jim has found a winner...SO FAR!
I just blind scanned AMC1 103W in 3-4 minutes. I used an analog clock on the wall to time it and didn't watch the second hand. RTV and the HD channels are not jerky nor do they stutter. 22 Khz is fixed! Can record in PS (Program Stream) or TS (Transport Stream) with no conversion necessary to play on a PC. I haven't found any major bugs...clock still don't work.
It has a Skybox boot logo and a darker swirled pattern when you hit menu than the Openbox FW but it looks good. Going to the Information screen and hitting 777777 doesn't give you the extra info anymore, you have to hit 888888 (however many times, I just hit it till it pops up) like it says for the S10.
Mine shows Chip ID 9D1A which is supposed to mean it is not a clone.
I'm going to post this as an S9 info thread because this is the best I have seen.
Finally something that may work until a clock fix which if this ones works as good as it looks then it is a keeper!
Why Do You Think S9 Has New FW?
Choice between 89W or 91W as Home Satellite?
