SIRSWB vs Cassette Adpater | SatelliteGuys.US
merlinmer
2
I have a new sportster (about 2 weeks) I was just wondering which gives better sound quality in the car, the SIRSWB or a cassette adapater? Does the SIRSWB work with the sportster?
thanks for the help
Those 2 options would be very close. The SIRSWB does require an adapter for the Sportster, and some people has reported that the adapter from Radio Shack doesn't fit in the housing very well. I'll try find a link later.
Sirswb???
What does the adapter look like, what does it convert... etc.. any info you can give? I just bought the sportster, and am finding that the wireless fm modulation sucks.
Welcome to Satelliteguys!!
If your car radio has CD Changer controls you can also get an adapter from P.I.E that turns it into an aux input for your satellite radio receiver. It does cost more than the cassette and FM switcher that you're looking at but this will give you the best possible sound with your current setup.
MLB on Satellite Radio in 2005
Scott Reviews XM's Opie & Anthony
