Sirius Sporster 5 & Tundra 2008 Install | SatelliteGuys.US
  • Thread starter Thread starter FredSG
  • Start date Start date
  • Replies Replies 0
  • Views Views 3K
FredSG
5
Hi,
Thought I would post my Sirius Sportster 5 install in my Tundra. I have the mini-dot antenna mounted on my dash, just in front of the center speaker. The antenna wire comes down just to the left of my radio. You can see my Sirius in the photo. Sorry about the dust! I drilled a 3/4" hole in the console cover and put all the wires in that cavity below the cover. I used the mount that came with the Sirius and attached the suction end to a plastic disk, which has a 3m double sided tape and attached the mount as you can see in the photo. I ordered the suction disks from Mount Guys, and they work great for me. I can see the Sirius OK and the antenna dash installation has been just fine.
Thanks for looking,
FredSG
re-activate ... and then bend over backwards.
XM Promotions
