Sirius Car Antenna vs. Car Wash | SatelliteGuys.US
donellyd
2
I installed a new antenna on a new SUV in Dec 07 and I have now lost reception on that antenna (new one works + old one doesn't work in boom box or home doc). Aquiring signal is what the Sportster reads w/o ever picking up a signal.
The guys at Sirius say it is because I use an automatic car wash. Especially funny, since in the install book it says to let the cable protector adhesive to set up for ~72hrs prior to going through a car wash.
Anybody heard of such a thing? If it is true is the work around to put a piece of tape over it prior to entering the car wash?
I would strongly suggest that you just remove the antenna before you go into the wash. I never found that cable protector to be very strong anyways and my antenna just sits magnetized on my trunk. Haven't had any issues in the 2+ years that it's been on car with that setup.
My antenna is hard wired to the SUV; wires buried, etc. Impossible to remove. Am I the only person with a Sirius permanent install who uses a car wash??
I recall the tech saying there's a metallic coating that helps pull in the signal that will get worn off via auto car washes.
XM Sirius Satellite radio merger is now complete
The Low down on the merger
