1 1stTimer Member Original poster Aug 7, 2004 8 0 Nov 2, 2008 #1 Would this installation work DP Twin LNB (110/119) & DP Dual (129)-----> DPP44-----> DPP Separator-----> 722 Or will I need to replace my old DP LNB's for DPP LNBs
HIFI Resident Psycho Pub Member / Supporter Lifetime Supporter May 9, 2007 9,134 359 surfin SATGUYS in a round room with padded walls Nov 2, 2008 #2 yes that will work just fine,but if they are that old you may want to check them for drift
1 1stTimer Member Original poster Aug 7, 2004 8 0 Nov 2, 2008 #3 "check them for drift" What does that mean?
HIFI Resident Psycho Pub Member / Supporter Lifetime Supporter May 9, 2007 9,134 359 surfin SATGUYS in a round room with padded walls Nov 2, 2008 #4 use the search and look for "LNB drift"
HIFI Resident Psycho Pub Member / Supporter Lifetime Supporter May 9, 2007 9,134 359 surfin SATGUYS in a round room with padded walls Nov 2, 2008 #6 no problem,it is much easier than having yet another thread on drift
boba SatelliteGuys Master Dec 12, 2003 11,350 1,036 Dorchester, TX. Nov 3, 2008 #7 If using a separator you must USE A DPP TWIN or DPP44 switch. Separators will not work with DP TWINS without a DPP44. LNB Drift will not stop that combination from working but may give you breakup or intermittent signal problems.
B bigstick New Member Nov 3, 2008 1 0 larksville, pa Nov 3, 2008 #8 I have a dishpro plus lnb head on a dish 500, how do I hook up the second receiver? Bigstick
G garys SatelliteGuys Master Sep 29, 2005 7,621 37 Greentown, Pennsylvania, United States Nov 3, 2008 #9 bigstick said: I have a dishpro plus lnb head on a dish 500, how do I hook up the second receiver? Bigstick Click to expand... Lnb should have a second output. Run coax from lnb to receiver and run check switch.
