Since transition I lost ABC | SatelliteGuys.US
ncted
6,130
4,346
Durham, NC
Since the DTV transition in June, I no longer receive a good signal on ABC which is now channel 11. I have a CM4228 in my attic. I have tied the screens together using zip-ties, but what used to be the strongest signal I got now is marginal at best. My question is, can I get a decent VHF antenna and combine the VHF and UHF signals somehow?
Thanks,
Ted
Thanks,
Ted
Sure. A UVSJ will add a VHF only to the UHF antenna that you have.
Two options for an antenna are Antennacraft Y10-7-13 or Winegard Y1713
Please help with antenna question
Apex DT250 pictures and info
