Signal test Audio | SatelliteGuys.US
Signal test Audio
menos1
4
colonial beach, va
Good Morn good people, my signal strength on 103b was way down in the 40's/50's, so decided to try and tweak the dish. Went to the signal strength meter screen for individual transponders. Was able to see the bar graph showing singnal strength buy no audio out of the speakers. Normal audio connection is optical from h-20 to amplifier. I switched the audio to the TV speakers and it was fine. Any idea why the signal strength audio beeps will not pass through my amplifier. Just FYI, adjusted the elevation on the slimline and signal strength went up high 80's to low 90's. THanks. Mike.
I don't believe the HR's pass audio for the signal meter like the old receivers did. Mine don't have audio either on any of them and all are connected via HDMI to the TV (no audio equipment).
Yes, it's been awhile since the Audio portion of the SS menu has worked for me.
It use to be handy , but for some reason they don't work anymore.
You would think they would do away with the option.
Jimbo
AM21 Question
Do DirecTV installers use railing mounts?
