Signal Strength | SatelliteGuys.US
Signal Strength
Dish416
49
Detroit
I recently switched from DirecTV to Dish and noticed that the signal strength in the 722k menu is super low. *I am not experiencing any signal disruption*, even in the rain. Is this normal? The technician told me that he was pulling high numbers on his signal meter and said the 722k does not show accurate signal strength.
True?
The dish meter is not a percentage meter. Notice that it goes to 125. Any signal above around 40 should not see rain fade during a normal storm.
The meter was renormalized more than 2 years ago. The max was 125 and is now under 100 with few/any reporting having more than 70. It is a relative scale and has no absolute significance.
If under say 15 (25 in the old days) you will always have trouble and the meter goes from green to yellow and then red. It is best to re-aim if it is below 30 (40 if you have rain or clouds) on the standard test transponders--see Menu+6+1+3 when not recording.
You can test if you can improve it by listening to the tone and applying finger pressure on the rim--not enough to shift it.
-Ken
Can antenna be extended on the 612?
So when will EHD archiving actually happen if ever?! Any ideas?!
