Signal strength on 129? | SatelliteGuys.US
Mr Tony
3,415
14,970
Mankato, MN
This is for the people who have rigged up a LNB for 129
What kind of signal do you get (like on TP17, where the Dish1000 screen is)
I tried it last ngiht with a 18" aimed at 129 and the best I could get was 77..this was on a DP301 receiver
anybody got better?
I asked the same question in another thread and didn't get any answers. Here in the Bay Area, I tried TP 20 and I was getting 78 with a 501 and a Dish500. Aimed it back to 148.
Is this a low powered satellite? At least it appears that way.
what receiver?
damn..those numbers I like :)
(I know that Minneapolis has a must carry that is there (KAWE PBS) so I was just seeing TP strenghts) :)
might have to try a little harder :)
This is my setup a superdish on 110/119/121 a dish500 at 129 am running these on 2 811's also have wildblue for internet as of this moment still TP17 is 86 and highest still 103 on TP10 and it is cloudy here today
I had a signal of 95-105 (don't remember the TP's) when I had my Dish300 pointed at 129.
This was on a 921 receiver in southwest Michigan.
Hey Iceberg,
I can't remember specifically TP17, but I got 0 for 20, maybe around 50 for TP4 and 5. For the others the max I'm getting is maybe around 67-70% I think I was able to get more at a certain point, but I can't find the location anymore. since I still get all the voom HDs anyway, I'm satisfied for now. I have a dish 500 and 811 receiver.
anybody got better?
With the new 1000 dish we picked up 129 at 68 just last week from Portland, Or. I'm skeptical since the dish was on a rubber non-pen mat and not peaked with the 129 lnb. I'm willing to bet it would have been in the low 80's otherwise.
sounds like I shouldnt use my homemade mast (its a mast bolted to a couple 2x6 boards and clamped to the deck railing...I use it for test rigs :)
I might slap a LNB on my G10 dish or my StarChoice dish :)
SatinKzo said:
Iceberg What about that setup you had with the extra lnb hose clamped on your dish500?
took that down. I have had a crappy signal on 110 for a while now (most TP's 75-80...a couple in the 60's. No matter how I tried to skew it, I couldnt get good signals on both 110 & 119.
So I took down the 20" DIsh500 and put a 18" DirecTv dish up for 110 only. I have a StarChoice dish that I was able to put a LNB for 119 on it (starchoice is at 107 & 111) and was able to get 122-125 on all TP"s on 119 (sans spotbeams) and 115+ on all TP's for 110
They're tied together with a SW21 :)
What is the difference in the skew/elevation when tuning in 119 and 129 compared to what your settings would be on 110/119? Will a twin work or do you have to use two seperate lnbf's on the Y plastic yoke to move the lnbf's a little to compensate for the 1 degree difference in spacing?
When we first heard about Voom mirroring over to 129 I pointed a Old Dish 300 (on a Tripod) with a DP dual, and had signal at about 98 on tp 17 with and 811. In Phoenix BTW.
Distant Networks Question??
Record from 721's Cable Input?
