Signal Splitting Question | SatelliteGuys.US
8bitbytes
3,239
NoVA
I currently have two dishes, a 500 for 110/119 and a 500 for 61.5, that feed into a DP34. Two cables then leave the DP34 and go into the house to feed my 622. Is there a splitter/switch I can put on on of those two cables to run to another room and can that new third cable be split to feed two tuners?
I am not able to wrap my head around this one so I appreciate your responses to this question!
And, no, I currently cannot run another line or two from the DP34 into the house. I wish I could as this is the easiest solution!
Thanks!
"And, no, I currently cannot run another line or two from the DP34 into the house."
Then you can't add another receiver. You can't split the satellite signal to feed another receiver. Your only chance is to run the cables to feed the other receivers.
No, but you could get rid of the DP34 and replace the DP Twin that you most likely have on 119/110 with a DPP twin, and plug the DP dual you have on 61.5 into the DPP Twin. Then you could run one cable to each dual-tuner receiver.
Ok! That's cool. Thank you, that's exactly right. I wasn't thinking past the DP34.
Dish HD Locals via Satellite a travesty
Problems with chat tonight
